Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: R clip on rear brake pads, advice needed  (Read 582 times)
Offline steveharleyuk
  • Bike: S1000XR SE Sport
  • Town: gloucester
« on: November 08, 2019, 01:10:05 PM »
Novice at servicing here. Just changed the rear brake pads, had some trouble getting the r clip back on to the spindle. My question is does the r clip have to go through that little hole in the spindle? If so I'd have a hell of a job lining that up. I've just clipped it over the spindle at the moment and it's gripped but is that right?
Offline SimonUK
  • Bike: S1000XR,S1000R
  • Town: Upstate, SC
Re: R clip on rear brake pads, advice needed
« Reply #1 on: November 08, 2019, 01:55:04 PM »
yes, it has to go through the little hole. It is not really a big deal to get the hole lined up, when looking from the rear, it just needs to be close to between 11 and 1 o'clock, you can then get the tip of the clip in and it should rotate pretty easy.
Online RyanGTXR
  • Bike: KTM 1290 GT
  • Town: Notts
« Reply #2 on: November 08, 2019, 01:55:32 PM »
If you mean the pad retaining pin then yes the r clip goes through the small hole. That is what stops it from coming out
  • Town: gloucester
« Reply #3 on: November 08, 2019, 03:27:46 PM »
Thanks, will have another go!
Offline bobdave
  • Bike: BMW S100XR
  • Town: Bournemouth
« Reply #4 on: November 09, 2019, 12:16:53 PM »
If you apply a tiny coating of copper grease to the pin before you replace it I found it is much easier to rotate and line up the hole for the pin - obviously don't smear grease everywhere as that would impact the brake performance !
