Author Topic: Rosso 2 tyre pressure recommendations  (Read 420 times)
Offline Demonbiker
  • Bike: X-ray 1000 sport
on: April 04, 2021, 08:00:52 AM
Hello everyone, new here...
Wanted to get some of your values opinions on the tyre pressures that you are using on the road with Rosso 2’s ?? Are most of you using standard pressures...ie 2.5 bar front and 2.9 rear ? What have you found works for you ?
Offline runnerhiker
  • Bike: '19 S1000XR
  • Town: Niwot CO USA
Re: Rosso 2 tyre pressure recommendations
Reply #1 on: April 04, 2021, 10:25:51 PM
My conversion app is not working, I'll have to go with 36 psi front and 42 psi rear as the recommended number.
I use 36/42 as a max number and I am ok allowing the pressure to run as low as 31/37 psi.  Actually, if I am going on a trip with the bike loaded, I make sure I am at 36/42.  If I am on a day ride on the twisties, then I like 31/37 better.
36/42 is very important for load capacity.  31/37 works better for handling.
