Author Topic: Saving weight  (Read 3947 times)
#50
Offline Crosshairs
  • Bike: 2018 S1000XR
  • Town: Oceanport
Re: Saving weight
Reply #50 on: November 24, 2021, 03:36:29 PM
*Originally Posted by Becksy [+]
If I remember correctly….?
correct.. :)
Proud member of the 10/40 club
#51
Offline Crosshairs
  • Town: Oceanport
Re: Saving weight
Reply #51 on: November 24, 2021, 03:45:40 PM
*Originally Posted by JerryG [+]
IIRC?
What did you remove?
 A few things that I felt were not needed.
Last Edit: November 24, 2021, 03:46:21 PM by Crosshairs
#52
Offline Salem
Re: Saving weight
Reply #52 on: November 24, 2021, 04:40:29 PM
Whenever I work on the bike I remove useless labelling. Mostly found on wiring. But also that totally useless tire pressure decal on the swing arm  2.5 / 2.9 in every case... I managed to remove for sure 0.002 kg. Have to do it again on the new bike....
#53
Offline JerryG
  • Bike: 2021 S1000XR
  • Town: Hendersonville
Re: Saving weight
Reply #53 on: November 24, 2021, 05:13:07 PM
*Originally Posted by Crosshairs [+]
Well, I'm sure we'd all appreciate a bit for detail.
#54
Offline Crosshairs
  • Town: Oceanport
Re: Saving weight
Reply #54 on: November 24, 2021, 10:54:15 PM
Actually Im pretty sure you have some sort of agenda ...or you just want to tell me I'm wrong about what I've done..at least thats my experience with you at the RR forum.
#55
Offline JerryG
Re: Saving weight
Reply #55 on: November 24, 2021, 11:09:05 PM
The only agenda I have is that I'm impressed with how much weight you removed and I would like enough information to do the same. Why else would anyone be participating in this thread?
#56
Offline lospsi
  • Bike: BMW S1000XR 2015
  • Town: Athens
  • Country: gr
Re: Saving weight
Reply #56 on: November 25, 2021, 05:28:55 AM
Ι would imagine that 10kgs savings would be possible by removing or replacing:
- the center stand (that's about 2kgs I think)
- rear rack and replace it with a carbon cover ( it's heavy, I would say 2-3kgs)
- the exhaust system (gains here should be 2-6kgs depending on if you go for full system or slipon)
- passenger rearsets (I guess around 0,5kg)
- handguards/mirrors (should be over 1kg)
- number plate holder (about 0,5kg as well?)
- the battery with a lithium one (from previous experience, it should be 2-3kg)
I would imagine carbon parts would be lighter too but stock plastic parts (ie fenders) are also quite light so any gains should be marginal. Titanium bolts are way lighter too but the differnce is in grams so total weight loss should also be marginal, assuming that you'll change A LOT OF bolts.
Oh, and assuming one wouldn't add parts (like guards, protection, etc) :002:
Last Edit: November 25, 2021, 05:33:41 AM by lospsi
#57
Offline Crosshairs
  • Town: Oceanport
Re: Saving weight
Reply #57 on: November 25, 2021, 02:11:11 PM
*Originally Posted by lospsi [+]
You got the gist of it...and it should be noted that none of what I did was ever intended solely to remove weight, it was done for performance
and personal preference.
Ive about the same to every bike I've owned
Last Edit: November 25, 2021, 02:11:47 PM by Crosshairs
